Engine on the bench. 6mm side cover screws were snug--every one of them needed the impact driver to loosen it.
Clutch basket looks good. But, someone has been in here before! Those nicks on the primary drive nut are not mine (I use the proper tools to flatten the lock washer) and I would not re-use an old lockwasher on the primary drive pinion. The gear teeth seem to be good; no spalling or pitting.
I took off the clutch and the right side stuff: points cover, points plate & stator and the alternator rotor. The rotor came off without any problems.
On balance the right side is in decent shape. The rotor still has lots of magnetism and there is no evidence of any water ingress or damage. The stator looks good although I haven't done any electrical checks yet. The 2-stroke oil sitting at the bottom of the casing on both sides suggests that the outer crank seals need to be replaced. For an engine of this vintage I'll send out the crank to get the center seals replaced too. The points cam was rusted and deeply pitted. This might have happened due to wet felt 'wipers' when the bike was parked. Since I plan to run points and condenser ignition, the points cam will be needed. I could try to polish out the pits but a lot of material would need to be removed. So, I've ordered an aftermarket replacement points cam from HVCCycle in Lincoln, Nebraska.
