Hey there, new user, first post.
I have a 82 CB 750 Engine that I want to repaint. I'm not looking to tear down the cylinder heads and block. Just want to paint it while assembled. I have done a few of the covers by baking them in my oven, looks great, and seems very durable. Question is, how can I cure the primer and paint on the engine? Obviously too big to fit in any oven I have.
Is it enough to prime and paint then resemble and run the motor to cure the paint? I know that is what the label on the can says, but I wonder if some locations around the pan and clutch area wont reach the high temperatures required for a cure?
Also, does if matter if the primer and paint are heat cured as one?
I'm using VHT engine - primer and paint.
Any advice would be appreciated. Thanks!
-Luke
