Frame paint turned out really well, it was a primer and paint combo and it's not chipping like I expected it to.
Fender on, tank on, wiring moved around under tank, rectifier installed, tail light and rear wiring done, rear signals installed, front signal housing painted and ready to install, front brake reservoir installed, gas cap swapped to keyless one, rear wheel back on, front wheel disc put back on, exhaust on, moved headlight up (just for you Fast1...it does look better), mirror on, put battery back in,
To do
-clean front brake (slave end) and install
-put in brake fluid
-put new front rim and tire on
-install front signals
-remove center stand
-figure out front fender (probably just install the old one until I get a better idea of what I want it to look like.)
-figure out why signal relay not working (install resistor)
-try out some different bar styles
-pull off carb and rerun lines, replace float bowl gasket and hide wires away from choke
TEST DRIVE!!!! I work all this weekend but sometime mid to late next week I should have a chance to get some of that list done and go for a ride.
I really like the tank and fender look but I've had a few folks so I should paint the tank the same scheme as the fender....thus making it the "Hans Bobber" I will leave the tank for now.
